TwinTurbo.NET: Nissan 300ZX forum - Your potentiometer may not be making contact.
Subject Your potentiometer may not be making contact.
Posted by ZiNnYc on April 08, 2010 at 7:00 AM
  This message has been viewed 89 times.
In Reply To Need help - Fuel gauge needle is an inch below E. posted by doug8867 on April 07, 2010 at 07:53 PM
Message Pull the pump from under center tray and check the lead/contact point.
4 philips screws, 6 8mm bolts, remove connector, crank engine to
relieve pressure, pull return and feed lines. 10 mins tops.
